electro7
- Northern CA, US
- Electrician, Solar and Electrical Contractor
Hi,
I am installing an interactive system with battery back-up. My customer wants a few of his shop circuits on the critical load panel. The issue I am having is his shop is 150ft+ away with 4/0 aluminum wire feeding his sub panel. I think it will be nearly impossible to pull new wire in that conduit to get circuits from there onto his critical load panel. I was thinking about using an automatic transfer switch between his feed from the service and the shop and adding the critical load circuit to the transfer switch. So when power goes out he has power from the critical load panel to his shop. The question I had was if the breaker from the critical load panel to the transfer switch was hot all the time if it would mess up the automatic transfer switch? I would rather set it up for him where everything is automatic. So when power goes out he does not have to go out to the critical load panel and turn on the breaker for his shop feed.
Hopefully this all makes sense.
Thanks
Thanks
