CSST & gas pipe bonding
M.D.
I don't think a gastite tech. bulletin changes the listing of a clamp that is listed for copper water tubing, who told them it is ok?
JohnJ0906 said:
What about non-copper water pipes? I see city water enter buildings with this pipe, and clamps are made for that. Are they listed?
I'm still curious about this. What about the clamps for bonding/grounding non-copper water pipes?
I seen, and used, ones that look like big u-bolts, with a connection for the GEC/bond wire. I just don't remember who made them. Are they listed for this?
Appleton has a clamp for both gas pipe and copper water pipe I guess I would use this one :smile:
Type GC​
Zinc​
Use:​
Ground clamps for bare copper conductor. For
insulated or bare conductor wire, copper AWG #2
through #8. Clamp is reversible.​
Material/Finish:​
Casting?Zinc Die Cast Screws?Steel​
Applicable Third Party Standards:​
UL Standard: 467
CSA Standard: C22.2 No. 18
NEMA: FB-1
Fed. Spec: W-F-406D,
Type 5, Class 7, Style S​
Note:​
GC-5 is listed for use with 1/2? through 1? trade size
copper water pipe, steel galvanized water pipe and
metal gas pipe. UL requires the UL logo be removed on
our GC-5B because we provide plating of a material or
color different from natural zinc.​
M.D.
that sounds like a winner, I wonder how available they are, thanks for the info
mpd , I have never seen a clamp solely listed for copper pipe. I'm not sure I even understand what the original concern was:confused: but I'm glad I helped ,.. if in fact I did.
Why,... the world wide web ,...of course. I used to work on the supply side of the counter and I remembered a little zinc clamp , then I went and found it.
George ,and anyone else interested , this link from allied has info that seems to fly in the face of using a zinc , or at least their zinc clamp , on a copper pipe, galvanic action , which is why I think the other company stresses the fact that thier's can be , may be, I don't know just a guess.
http://www.alliedboltinc.com/pdf/pipe-clamp.pdf
