CT Can
cpinetree
SW Florida
A CT is a current transformer.
Try this link to start: http://lmgtfy.com/?q=ct+can+electrical
Most POCO's require CT's and the can to install them in, on services over a predetermined size.
One local POCO in our area requires them on services over 600amp.
You will need to check with your POCO.
kelli
Austin
Thank-you! I sort of understood the why, but I wasn't sure about the when. I thought it was over a certain size, but couldn't remember what that was. Thanks again. You guys are awesome as always.
ggunn
Austin, TX, USA
The size where a CT meter is required varies from POCO to POCO.
