CT rated
Cstreeper
PA
PM
Is insulation level of CT 720 VAC line/3kVAC suffice for CT used in 15kV SWgr? I have a 15kV SWGR w CT MR 600A/5A CL C200. I don't understand the insulation level, or how it's rated to work with SWGR.
jim dungar
Wisconsin
PE (Retired) - Power Systems
Acronyms are not universal over our industry.
What do you mean by CT?
Current Transformer
Control Transformer
Current Transducer
I have seen all of these used in switchgear.
kingpb
SE USA as far as you can go
Engineer, Registered
Current Transformer
Control Transformer
Current Transducer
I believe you are incorrect, you should check the IEEE dictionary. CT is clearly indicated to be Current Transformer.
jim dungar
Wisconsin
Yep. But, I have been participating on this forum long enough to know that IEEE conventions are not regularly followed in discussions.
