liquidtite
- Ny
I see a lot of installs on ct cabinets are always piped out with rmc to enter the meter,even if the meter can't be nippled to the ct do to space .
Also I see a lot of the time when the ct cabinet
is outside the rmc is connected to the cabinet with just locknuts ,I thought you
would have to use a Myers hub or a rigid compression connector should be used.
So is it code or just comin practice?
