- Placerville, CA, USA
- Retired PV System Designer
Just add more poles!Original generators probably couldn't rotate fast enough for 400 Hz.
I have designed many load banks over the years. Most for testing aircraft generators and invertors. Don't recall if a 777 was in the group or not.I once did a project that involved making a load bank to test the 120kVA 400Hz generators used on the Boeing 777 aircraft. Each one was about the physical size of a little 1Hp standard induction motor, and that included the CVT transmission it needed to step down from the high shaft speed of the turbines. The alternator itself inside looked roughly like a car starter motor.
