plate
 - South East PA
wptski said:Karl:
I'd like to know about the zero button on your Extech, does it really zero in AC current or DC only?
The zero buttons are typically to zero for DC measurements.
per a fluke moderator: The zero input behavior of a true RMS multimeter is different from that of an averaging meter. With a true RMS meter you will never see 0 for the input measurement when readings are not being taken. The true RMS converters require a certain input level to make a measurement. So when nothing is being measured you will notice a deviation. The meter accuracy specifications still apply however and are not affected.
