Twoskinsoneman
- West Virginia, USA NEC: 2020
- Facility Senior Electrician
I've been trying to solidify my knowledge on unbalanced circuit to be able to explain it a little better to the guys that work at our shop. Anyway on a job where the rough in is done and there are only two circuits powered (window AC unit and radio/drop lights) I decided to check the amperage draws. None of the other circuits have receptacles, just wires pushed into the boxes. They are terminated at the sub panel. Anyway I couldn't figure why I had 5.5a on one leg .5a on the other leg and only 4a on the neutral. Scratching my head I tried the EGC and found the amp there. Is it normal during construction to have this happen? I figure at some outlet somewhere the neutral is touching a ground. Is this what you suspect also?
