Phil Devine
We are experiencing problems with some of the electrical systems in one of our new schools. We wanted to make sure that the neutral conductors are only bonded in one place at the main service disconnect. We have 7 ? 15 amperes flowing in a main equipment grounding conductor bonding the switchgear to the building steel frame. There is a debate here whether that is normal or not and whether further testing of the ground and neutral connections and grounded conductor insulation system is necessary.
Is it normal to have current flow on the grounding conductor(s) of a system (like a school)?
Is there an acceptable current value on an equipment grounding conductor?
