toolaholic
Had my appliance wizard go out. Mike replaces fried circuit board, and tells Me this. Disposal and D.W. On same 20 amp breaker in panel ! Typical around here. Install 2 breaker box under sink with one 15 amp breaker for DW. The previous owner did His own work and HACKED it all ! Pull service cover . I always do this. Pull each wire to breaker to make sure, Wow one arcs and pulls out !tighten. Wiggle each breaker, Bingo 20 Amp disposal and D.W. cracked ! Pull it charred real bad ! Replace. Will call Power co. to check Neutral at pole. Last Month tenant calls burnt smell from microwave outlet. Outlet wire loose and arcing! Burnt outlet. I should send former owner a commission . Any ideas appreciated .Tanks Tool
