I tested the outlet and I got 240v. from the Neu. slot and one hot slot. Three prong outlet. So I fixed that, and wanted to see if the Neu. and Grd. were bonded in the dryer. Just looking at where the cord was landed on the dryer, It didn't look like it was. So I opened the whole back panel to make sure. I saw the Neu. and Grd. were butt spliced together inside, where you couldn't see it. So I figured all disconnect the Grd wire screwed to the frame, and cap it off.
Plug the dryer in, and check to see if there was any voltage on the frame. There was like 82V. Ok? I didn't understand why? So in a last ditched effort I screwed the Grd back to the frame like it was. Voltage was gone.
Any ideas? Thank you for your help.
