I was curious if the arrestor that is normally connected to the cut-out on the primary feed-through which traverses from the 12,460 volt primary overhead line down the utility pole riser to go underground is a lighting arrestor or a surge arrrestor (otherwised known as a spike arrestor)?
This arrestor is seen in-line with my cutout, located between the cut-out and the riser on the utility pole. The cut-out is located between the primary 12,460 volt overhead and the arrestor.
Some folks keep indicating I am installing a lighting arrestor. That confuses me since a lighting arrestor takes a parallel path to ground I thought and is not in line with the circuit.
I have a drawing which indicates it is called a polymer arrestor. I assume this means ceramic polymer (need to go back and check my chemistry), but does not tell me if it is for lighting arresting or voltage spike (otherwise called surge) arresting??
