Re: Cutting conduit
The Tubing cutter if used correctly or reamed, does not narrow the pipe to where you can notice it or when you pull wire through it. If you put a connector on the end, and run your finger on the inside you will not feel any restrictions or reductions. I think it is much faster and easier.
Unibits work great in reaming the pipe, my worker taught me that trick a couple of months ago, I lost my tubing cutter and had to use a hacksaw for the day, and having to ream every time with pliers or file was no fun. I use the bit and it worked great. Just don't push too hard, it will expand the pipe and the connector won't fit on.
