Greg1707
- Alexandria, VA
- Business owner Electrical contractor
I had a frustrating experience yesterday cutting 3/4" FMC with a Sawzall. What is best practice to cut FMC?
I deal with it quite a bit. Usually pack around a mini portaband, I would say it’s probably the best to cut it with.(my opinion)Try a portaband, the blade teeth will pull it against the side of the opening.
Or a vise with sawzall
Bandswaw or break in half and trim with Klein 1104's .
Cutting with a swazall is the worst. I'd rather bend it till it pops open and cut it with Klein 1104's . Even before the cordless revolution a portaband is my first choice and now that everybody makes a cordless version it's a no brainer best way to go.
If clamping in some sort of vice you can get away with more. If holding in your hand while cutting with a reciprocating saw, a worn out blade does not do so well, a like new blade seems like a hot knife in butter in comparison. Do need to keep the work tight against the shoe of the saw in all cases.A fine-tooth blade is a must. Use a hacksaw frame if you can't slow the recip saw.
Also, you need more blade motion and less blade pressure.
Lol...thats right. Also, never-ever use your back...use your apprentice and while cutting, don't get bloody, cut towards your buddy!Or have your apprentice cut it.
