cutting holes in plaster with thick mess??
I've had to do the same here, only through stucco that had a 'chicken wire' mesh.
Sawzall is a bad idea; the action of the saw pulls on the mesh, breaking out material outside the area.
I have not tried the roto-zip, but my expierence using ine in 3/4 MDF makes me think that it might work well.
The grinder works great - especially with a diamond blade.
Now, your dust problem is going to be huge. For the grinder, you need to tent off the area, wear a mask and goggles, AND have some means of holding the vacuum hose as close to the work as possible.
For the roto-zip, catching the dust seems easier. Just holding the hose at the tool catches a lot; or, you can set a box over the spot, and do your cuttng inside the box. Clear plastic (plexiglass) on top, vac hose inside, you've got it made.
