electricalperson
- massachusetts
whats everyones tricks for cutting threaded rod and not damaging the threads? i usually take a wirenut and use that to restore the threads
I just use a shop saw, then make a 'cone' out of the end using the side of the saw blade.
- Band saw.
- Chop saw, use chop saw to also clean up the burrs
- Hack saw
- Sawzal
If I have a lot of the same size to cut I bundle large groups and cut them in one shot, again a band saw or chop saw works best for this IMO.
I agree with IWIRE but when I cut a bundle I wrap duct tape around the rod where I'm cutting it at so that the pieces on the inside of the bundle don't spin around.
Run a nut (or two) down past the cut, make your cut, back the nut(s) off again (cleans the burrs and thread) and it should go on easier next time...
Jim
I keep a file handy to trim off burrs...why run a nut a couple feet down a rod? That aggravates me.
It aggravates me to, but when all you have is a sawzall, it sucks trying to get that nut on afterwards. I'm sure I'll learn the way to do this right here quickly.
Jim
