cutting threaded rod
If you're up on a lift cutting lots of odd pieces of threaded rod, the Greenlee threaded rod cutter is really handy.
how much does one of those go for? maybe santa claus can afford one
I couldn't really swear that they were even still made, but it seems they are. About 500 bucks from what I just Googled. You don't need to file or chamfer, because the cutter has a thread profile in the scissors-type dies. As long as you nest it in the grooves before you mash down on the handle, you get a factory type cut. Does 1/4 and 3/8 rod. If you're running big racks on 1/2 rod, you still need to saw the old fashioned way. 1/2" rod, luckily, almost never needs deburred or filed to get a nut to start on unless you really messed up or your Sawzall jumped all around.
