big john
- Portland, ME
So I've gotten an interesting new job as an electrician for some hydroelectric dams and I need to come up with a battle-plan to combat the effects of water on the electrical equipment. There is a tremendous amount of water seepage through the dam (surprise, surprise) which, combined with the chemicals in the concrete quickly destroys any metal. A lot of equipment cannot be replaced just yet and has to be "fortified" instead.
Thanks a bunch.
-John
- I'm thinking of making it a policy to use PVC and fiberglass anywhere it's in contact with the dam face.
- Use some sort of antioxidant on electrical connections to help prevent corrosion and galling. Would NoAlox work on lightbulb threads and copper connections? Not sure about high-heat and copper applications.
- Liberal use of silicone, duct-seal, and weather-proof fittings to help prevent the incursion of water.
- I've thought about wrapping all devices and connections in tape, but I'm not sure if any amount of tape would make a difference in a high-humidity environment. Maybe just a waste of time?
- Some type of corrosion-inhibiting coating. CRC advertises a bunch of sprays that are supposed to inhibit corrosion on electrical equipment. I'm weary of anything that simply gets sprayed all over the place. Is the stuff a conductor or an insulator? Don't I run the risk of making things into insulators/conductors when I don't intend to by coating them?
Thanks a bunch.
-John
