goldstar
- New Jersey
- Electrical Contractor
I was asked by a GC to provide a quote for 8 recessed lights that are going under an outdoor deck. The decking will have a rubber membrane laying across the top of the joists before the decking goes down so I can use new work cans below. Once the cans are installed there will be a ceiling installed (probably some form of decking as well). They also want to install 2 paddle fans under this deck. So, here are my questions :
Thanks in advance for your opinions.
- Does anyone know of a recessed light fixture that I can use for this application ? I don't know that the area between the joists is going to be excessively wet but I'm guessing it may be damp. Deck will be pitched away from the house to allow water run-off.
- What would you use as a wiring method ? I'm thinking UF cable and the appropriate UF connectors
- What would you use to support the fan ? I'm thinking a regular fan brace & JB. HO is buying the fans
