Fulthrotl
~Autocorrect is My Worst Enema.~
- E
I have always had a very strict policy on personel protective grounds, controlling them is very important, I use additional tags on the LOTO point that says "Warning, PP Grounds installed" and include the assigned number for that ground set (The ground cluster is tagged with a number also).
the shorts and grounds i mentioned were not applied by the holder of the
work clearance. santa's little helper was hard at work. shorts and grounds
always have the owner's tag on them. these were untagged....:-? they were
in the middle of a bus, between positions, and tied back so they were out of
the way... i was always told to hang the grounds way out there where they
stuck out like a sore thumb, not tucked neatly out of the way....
