Never had issues with that. If you need to repair chances are you have dug a big enough hole that at very least the smaller item will have enough flexibility to it to get it far enough out of the way. Items buried four feet deep - you will have a big hole(surface area wise as well as depth) just to be able to work in the hole, unless you have hired some pretty tiny workers.Don’t run side by side. Leave space between in case repairs are required after a dig up,
By space I meant a couple of inches so you can get a sawzall in between them to cut back and repairNever had issues with that. If you need to repair chances are you have dug a big enough hole that at very least the smaller item will have enough flexibility to it to get it far enough out of the way. Items buried four feet deep - you will have a big hole(surface area wise as well as depth) just to be able to work in the hole, unless you have hired some pretty tiny workers.
Place them couple feet apart, you have more risk of hitting one with excavation equipment than if they are close together.
If it is raceways your supposed to pull cable/conductors out then cut to make repairsBy space I meant a couple of inches so you can get a sawzall in between them to cut back and repair
