gar
- Ann Arbor, Michigan
- EE
110213-0812 EST
So far there is no clear cut definition for the statement of the problem.
I think it is clear this is not equivalent to a burglar alarm. In a burglar alarm system you are interested in the change of state from an intrusion. This sets a latch that must be reset by some means other than a return to the non-intrusion state.
The problem here I believe is personnel protection related to a machine (process). The type of system defeat you want to protect against is someone opening a panel or door and then with the item (door or panel) open having the person over-ride the sensor to make the monitoring system think the doors are closed so the machine can be run with the doors open.
A resistor at the end of the monitoring loop can not solve this type of over-ride. You have to in some way prevent over-ride of the door sensor.
But the starting point is an accurate definition of the logic of this monitoring system. Once you have a definition of the goal, then you can work on the system design.
