Weezy
- California
Hello all,
I am testing a pv system and discovered an unexpected reading. The test is a ground/feeder continuity test. It verifies continuity of the positive feeder, the ground system, and correct polarity of the feeders. Two 500mcm feeders are pulled from a disconnect, one positive and one negative, and terminated at a combiner box at the array. The outputs are pulled to an inverter right next to the disconnect and terminated. The positive bus and the ground bus at the inverter are jumped to created continuity. This is a positively grounded system.
Two thirds of the combiner boxes passed the test, testing at less than 1 ohm between the positive bus and the ground bus at the combiner boxes. The negative feeders all tested OL as they should, proving correct polarity. I have about ten boxes that failed, from four different inverters, all tested the same way. All ten of the combiner boxes that failed are in the center the structure. The feeders rang out but read from 9 ohms all the way to 14 ohms from the positive bus to the ground bus. I have checked for voltage at the combiner boxes and got nothing. I tried the test at the disconnect and they passed. Voltage at the disconnect was occasionally -0.1 v. I've tried three different meters and testing at different times of day and they always fail. Why would most pass and some fail? I established continuity but high resistance. I feel the ground system is solid. I'm curious why if I change leads during the test and use the black probe on my fluke on the positive bus instead of the red, the reading goes from 10 ohms to 0. Why is this? Does this mean there is some voltage? I am not finding any. The Ac side of the inverter is already terminated at both ends but none of the equipment has been turned on. I've already completed a thorough string test and everything passed.
Any thoughts or suggestions are appreciated. Thank you.
