I have multiple questions about the correct amperages to print on the "DC LABEL".
This is the label required on any DC system that lists:
Rated Maximum Power-point Current:
Rated Maximum Power-point Voltage:
Maximum System Voltage:
Rated Short-Circuit Current:
Take this example: module Imp is 8 A, and module Isc is 9 A.
a. If only one string in system, then what are the amounts to print in the two lines?
b. If two strings and I combine in a CB, then what are the amounts to print in the two lines?
c. If two strings but I do NOT combine in CB, but run in separate conductors to single inverter (where they are combined in effect), then what are the amounts to print in the two lines?
