080608-2135 EST
pc mark:
Let us assume your DC motor is run at 2000 RPM. Was the original gear box producing 38,000 RPM at the output and now you are trying for 58,000 RPM, or was the original output shaft 105.3 RPM and you now have 69.0 RPM.
I really assume you are trying to reduce the output speed.
What kind of gear box was the original reducer? Was it a spur gear or worm gear? Is the new one the same type as the original, or did you change from spur gear to worm gear?
Increasing the reduction ratio will increase output torque for a fixed input torque. However, usually it is the load that defines torque, but that does not change the previous statement.
Every time you increase the ratio of a gear box there will be increased losses in the gear box for the same output load torque.
If you have a job that requires a certain amount of energy to perform the task, then increasing the gear box losses will require more input energy. An example of a task that requires a fixed amount of energy is --- raise 100 # 100 ft. How fast you do this has nothing to do with the energy put into raising that weight. Do it in 1 second or 1 hour and the same amount of energy is put into the weight. This requires 10,000 ft-pounds work (energy). Do not confuse ft-lbs of work with #-ft of torque. Note: torque wrench manufacturers incorrectly label their torque wrenches in ft-#.
However, the rate at which you raise that weight may have a lot to do with the input energy to raise the weight. This will be a function of the efficiency of your raising system.
