strugglinsparky
- Fort Collins, CO
I have a customer who has DC lighting in a cabin. It is a remote area of Colorado. He currently hooks up a single portable battery, but will eventually want to get solar power. He the place brought up to current code. With solar we would use an inverter to change from DC to AC and would run everything with AC. For now the only source is a DC battery. I believe by code I would need two separate panels,with separate sec's, one for the lighting for DC and one for power AC, hooked up after an inverter, fed from the battery. Is this correct? I think I should just change the lighting to AC and feed a single panel from a inverter, that could be used later for the pv system. With only one battery being used as our source, he wouldn't be able to run lighting for any length of time with a inverter to AC Thank you for any knowledge you can share with me.
