steveng said:i am providing a dc circuit for 2 set of bar lights(cop cars), they light bars are rated at 20 amps dc 12volts
LarryFine said:There's a difference between "provide a 20a circuit" and "this device uses 20a", so the answer depends on this.
Otherwise, can you get ahold of a DC ammeter?
Obviously, the math says no. The transistor temperature will tell you for sure.steveng said:ok, larry, my power supply is a 12volt dc 30 amp continous.
my bar lights are rated @ 20amps 12vdc,
can i put 2 of the bar lights on this power supply?
LarryFine said:Obviously, the math says no. The transistor temperature will tell you for sure.
