Let's say the difference between string A and string B is 500 watts... can you make each string a max of 6500 watts? or does the difference between the strings have to be exactly 1000 watts, instead of 500 watts? By saying 'maximum power difference of 1000 watts' seems to imply anywhere from 1 to 1000 watts.
It can be up to 1000W of STC power difference among the strings, or it can be completely identical strings with no difference at all in nominal power. Given typical module power ratings available today, and assuming a uniform module selection, 1000W at STC would typically be a difference of 1 or 2 modules, and at most be a maximum difference of 3 modules. You'd have to have modules that are either 250W (technology of 8 years ago) or 500W (enormous modules today) to get a difference in power ratings of exactly 1 kW, and that is an unrealistic expectation.
The takeaway here is that you have less flexibility for diversity among the strings, when one of your strings is between the standard upper limit of 6kW and the fine print upper limit of 6.5kW. The inverter has to increase the voltage above 400V, in order for a string to operate at 6.5 kW. All strings that are paralleled need to operate at the same DC voltage to meet Kirchhoff's voltage loop law. The higher the voltage, the harder it is for your smaller strings in the same parallel group to catch up with the larger strings, to achieve the same voltage.
