I've got a question regarding voltage drop on DC circuits. A local airport has all DC runway lighting, supposedly because of the distance involved. How does DC compare to AC as far as voltage drop goes?
Actually no inductive or capactive components of impedance, there is still resistance (Z=R+X).DC Should be less with other factors being the same, no impedance.
Actually no inductive or capactive components of impedance, there is still resistance (Z=R+X).![]()
I'd be quite surprised if there was any real difference between AC and DC for voltage drop in such an application (assuming 60Hz). The reason we use AC instead of DC for our power transmission and distribution system is because of the efficiency of which AC can be easily stepped up to a high voltage for transmission and distribution, and then stepped back down for utilization. While recent technology has made it more feasible to do the same with DC, in general, it is much less expensive to do with AC. I'd suggest there may be some other reason that the airport chose a DC lighting system.
I would guess the other way, because incandescents run just fine on AC or DC, and the DC supply itself would have a cost.I am guessing an airport would use DC lighting so they can have a battery back up power the system in the event of a power loss, simple system for critical application with as few compoents as possible.
For smaller cables it isn't a lot different.I've got a question regarding voltage drop on DC circuits. A local airport has all DC runway lighting, supposedly because of the distance involved. How does DC compare to AC as far as voltage drop goes?
Well, you can't go on that. British electrons behave differently. Everyone knows that. :roll:This from the cable tables in BS7671 - a British Standard for Electrical Installations sometimes referred to as "The Electrician's Bible".
Aye, the are better behaved.Well, you can't go on that. British electrons behave differently. Everyone knows that. :roll:
Thanks for all the replies, guys. I was told by a questionable source that DC was used in this application for its voltage drop advantage over AC. It sounded a little fishy to me, so I figured I'd run it by you guys. So basically, there really isn't much of an advantage in using DC as far voltage drop goes, unless rather large cables are used. Does that sound about right?
If I recall most airport runway lighting is wired in series supplied by a constant current regulator and each fixture has a shunt to bypass a dead fixture.
