Rampage_Rick
- British Columbia, Canada
Same thing with the Volt. Gas engine is started by a motor/generator off the 360V battery. Computers and accessories are run off a 12V battery, charged via a DC-DC converter. A/C and heat are powered off the 360V bus.
If the 12V battery is dead there's nothing to boot the computers and energize the 360V bus. However, because you don't have to crank the engine it should only require a few amps to jump start. Excluding the load from the dead battery, it should be possible to jump start with 8 D batteries. Once the computers boot they will energize the 360V bus and everything will run off the DC-DC converter. It shouldn't be possible to run the 360V completely dead; since it's Lithium-ion it would probably require replacement.
