I have a 480V starters deadfront panel with a disconnect switch mounted outside of the panel. Do UL or code requires a interlock between the disconnect switch and the panel door?
430.102 Location.
(A) Controller. An individual disconnecting means shall
be provided for each controller and shall disconnect the
controller. The disconnecting means shall be located in
sight from the controller location.
