Thanks guys. Been doing some looking and thought I would throw this out there.
What about say buying some 6-inch IC remodel cans with Edison base, and then go buy some Cree 12 watt watt CR6 lamps? Could even be Lithonia or Halo as all 3 manufactures make them. I can get the cans for about $8 to $10, and the LED's fro $26 to $35. What am I missing here?
I rewired a restaurant about two months ago and used this type of setup. It was spec'd on the print. Slick install, nice look. about $40 total for can and trim
About a year ago, I wired a kitchen remodel for a customer who was determined to go LED for every fixture (4" cans, pendants, tracks, UCLs, etc). I suggested using a standard can and trim, with a screw-in LED replacement bulb. The benefits - it's a standard can, trim, bulb install, with a better selection of trim styles. Plus, the bulbs can be changed by the customer if a bulb goes bad or if they don't like the color temp. Cost was still about $40 each.
I suggested the same setup for her track and pendant lighting. It saved her a lot of money to buy 120v fixtures rather than LED fixtures, and there was a far better selection available.
If you use dimmers, you might have to make sure the bulbs are specifically listed by the dimmer manufacturer. I bought Lutron dimmers with Philips bulbs, and they weren't compatible. The bulbs only dimmed about 20% before they shut off. Went with Sylvania bulbs and they worked perfectly
Also, I think less expensive LEDs can be more prone to have variances in color temp. If they're really close together, it can be noticeable. I've seen this with LED ribbon especially.
