roc_clmbr
- DesMoines, Iowa
I am trying to find in the NEC 2011 when I can use a smaller size Neutral or Ground wire in a Circuit. For instance I am wiring a 240v 50 amp pressure washer receptacle. I pulled 2- 8 gauge Blacks and 1- 10 gauge Green. Is this OK? At what wire size or Amp rating can I change sizes. Thank You
