Adamjamma
- Jamaica and london
I may be wrong but it seems like dedicated wiring is needed for the two outlets described. Now, the washing machine circuit is easy because we have basically agreed in another post that one would be able to run more than one outlet on this circuit, for an ironing board and a washing machine, so one could use a gfci outlet above the machine, and feed from it to the plug spot behind the machine thus by tripping the gfci outlet you can shut power to the washer as well. Plus the outlet for the washer is protected by gfci.
But, can you do the same for the kitchen outlets? Could you for instance put a gfci outlet above the counter, run from load into a double pole switch, then into the outlet under the sink for the garbage disposal, thus providing gfci protection for the disposal?
and do the same for the dishwasher?
This is theoretical for now... because in the UK I normally use a fused switch above the counter for any outlets I put in under the counter, such as dishwasher, washing machine, etc... so they can be disconnected before I start trying to pull equipment out from the cabinets.
Personally, would love to see something like a fused switch with a gfci on it for undercabinet items such as fitted appliances, if the drive to full afci and gfci protection continues...but that is a personal choice...lol
