steve60tuesday
- Southern California
In a residential application we are looking to install some networking, cable, & internet access equipment. The place already has cat5 & rg6 run from every room to a laundry room downstairs, as well as from the demarc outside. Conveniently, the main panel is located in this same room, and everything is surface mounted on foundation walls with exposed romex between rafters above. So this is a very easy place to work.
Presently there is a single duplex outlet for the washer and (gas) dryer in this space. It is a dedicated 20A circuit with a standard duplex GFCI outlet.
My question is, is the dedicated laundry circuit exclusive to laundry equipment only? Or is it simply exclusive to the laundry area?
What I'd like to do is swap out the single duplex box with a double duplex / quad outlet. The other two outlets will power semi-permanently installed networking equipment. This stuff will be wall mounted nearby. It is definitely very low power equipment -- a small UPS in a datacom box with a DSL, router, and switch, etc... But it is definitely not laundry equipment.
Can I add the second set of outlets in this space, or should I pull a new circuit from the main box?
