charlie tuna
- Florida
as i remember harmonics was a new word in our industry in the early 90's and that their main creater were power supplies. as soon as the problem began apparent, they came up with a cure through electronic circuitry to near limit or reduce harmonic currents. but there were already millions of the harmonic causing power supplies in use and also many in manufacturing etc. at that point. so what the industry was looking at was a slow increase in harmonic problems and then a slow reduction. and from what i have seen in the infrared scanning business, this has occurred. i would say around 1997 might have been the peak for hot or overloaded neutral connections. i don't believe it is much of a problem today. also most of the new construction and engineering design has asked for dedicated circuits in data areas, so there is little exposure to the use of common neutrals which is where harmonics used to be a problem...................
