- Massachusetts
M. D. said:Unfortunatley it is a pretty good likeness as well.![]()
Well I probably look more like this guy...
safeguy said:Microwaves are kitchen appliances....and regardless of the amperage...the should be on a dedicated outlet....
tallgirl post #31 said:And there's a requirement that the counter top SABC receptacles not be above a certain height, so it's not like you could put one someplace "out of the way".
MA_Electrician1 said:Hello everyone. New member here![]()
Out of all the things they fill that book with you think they could add something like this!
iwire said:In my opinion that is not a safety issue, it is a design decision.
MA_Electrician1 said:The issue should be cleared up don't you think?
cowboyjwc said:All I can say is, when I turn on my microwave and my toaster oven at the same time the breaker trips. You can bet that as soon as I get around to remodeling my kitchen I'm putting the microwave on a separate circuit.
cowboyjwc said:All I can say is, when I turn on my microwave and my toaster oven at the same time the breaker trips. You can bet that as soon as I get around to remodeling my kitchen I'm putting the microwave on a seperate circuit.
Dennis Alwon said:So yes you could get by with a circuit that is not dedicated but you would have to watch the load.
The same would likely happen with a counter-top microwave and toaster-oven on an S/A circuit. That's why the 2-SA-circuit requirement is a minimum, not a maximum.cowboyjwc said:All I can say is, when I turn on my microwave and my toaster oven at the same time the breaker trips.
cowboyjwc said:You know us inspectors we only want you to do it the way we always did it : )
