Average poweris only meaningful if defined as the time average over an integral number of cycles of the instantaneous power.Average Power is:
A) Average (peak x .637) Voltage times Average Amps
B) RMS (peak x .707) Voltage times RMS Amps
If by average voltage you mean the arithmetic mean of the absolute value of the voltage, then your first equation is incorrect.
Your relations to peak value are only valid for a pure sine wave.
The RMS "average" was defined so it has the useful property that for any periodic waveform the second equation is true. (And you can argue that it is also useful, with a slightly different definition involving limits, for a non-periodic waveform.)
Average Power is:
Yes, a complete AC sine wave was my intentIf you average the absolute value of voltage over a complete AC cycle, you do indeed get 0.637*peak voltage.
It might not be a meaningful figure but Im trying to get an understanding of these relationships and the text books say RMS Voltages times RMS Amps equals Average Power. So Im assuming that there is no such thing as RMS Power.Since neither voltage nor current is a complete picture of the power on its own, it is incorrect to simply average volts and amps and multiply the two together, expecting a meaningful output......If you average the absolute value of voltage over a complete AC cycle, you do indeed get 0.637*peak voltage. But multiplying this with average current, doesn't get you any meaningful figure on power.
In phase and same shape.? So if there is reactance in the circuit, I understand that Pythagoreans Theorem tells you how to add horizontal true resistive with vertical reactive to get diagonal Apparent (Applied/Source) Power. But RMS reactive volts x RMS reactive amps should still = reactive VARs. And RMS resistive volts x RMS resistive amps should still = Watts.RMS is a fancy kind of average, that allows you to multiply RMS voltage and RMS current, to get the time average of power. That is, when both waveforms are synchronized in phase and have exactly the same shape.
Lets try a math approach:
1 peak volt x 1 peak amp = 1 peak watt
.707 rms volt x .707 rms amp = .707 x .707 = .499849 watt
So does this mean that the average (or rms) of 1 watt is .5 watt ? Is this the Average Watt.?
Technically, if you average a pure AC sinusoidal waveform over one cycle, you get 0.Yes, a complete AC sine wave was my intent...
When youre considering a real life circuit (that has both reactance and resistance), you will have Apparent (Applied/Source) Power, you will have True (Active/Work) Power, and you will have Reactive (Wasted Circulating) Power. You should be able to calculate both peak and RMS numbers for each power type even with a phase shift. The phase shift increases the reactive component and increases the theta angle and makes the triangle taller, but RMS is still .707 of Peak
You can't just use the real or reactive components
S = P + jQ = V I*
V and I is phasor or complex form and * is the conjugate
assume
V = 1/45 deg = 0.71 + 0.71j
I = 1/45 deg = 0.71 + 0.71j (* = 1/-45 = 0.71 - 0.71j)
S = 1/45 x 1/-45 = 1/0 = 1 + 0j va
or
S = (0.71 + 0.71j) (0.71 - 0.71j) = 1/2 - 1/2j + 1/2j +1/2 = 1 + 0j = 1/0 va
so
P = 1 watt
Q = 0 var
Using only the real V and I components: 0.71 x 0.71 = 1/2 watt NE P = 1 watt
Reactive V and I: 0.71j x -0.71j = 1/2 watt, not 0 var
Verbose comes to mind.That whole thing just shot right over my head
That doesn't make the average power zero though.Technically, if you average a pure AC sinusoidal waveform over one cycle, you get 0.
Yes you can. For power all you need is the real component.
Yes let's please limit the scope to a beautifully smooth and arcing sinewaveNon-sinusoids, i.e. harmonic distortion, make the relationship much more complicated. RMS will no longer be 1/sqrt(2) of peak. This is why I specified same shape.
RMS being 0.707 of peak applies to a single sinusoidal wave, centered upon zero. The power as a function of time is not centered upon zero. The voltage and current are, for a pure waveform of exclusively AC.
1 peak volt x 1 peak amp = 1 peak wattThe average power in this example would be 0.5 Watts. The instantaneous peak power would be 1 Watt. Both answers assume that both volts and amps are in phase and pure sinusoids in shape.
And so a 1 peak watt is .5 average watt
.637 average volt x .637 average amp = .637 x .637 = .405769 watt
Does this .405769 value have a label.?
thats a good visual image
