Now you're talking my language....
Can we get back on topic, please?
RMS current * RMS voltage gives average power.? Now youre talking like the text books. If you had said, average current * average voltage gives average power and average power is not a quantity that is of any use, that would end the conversation there. But when you say, RMS current * RMS voltage gives average power, my ears hear, a German woman and a German man were biological parents of a baby but the baby wasn't German.When you apply a voltage to a resistive load, the power delivered to the load is proportional to the square of the voltage. Because of this, the 'average' most used for voltage measurements is the 'RMS' average. You start with your voltage values, square them, take the common average of all these squared values, and then take the square root of this common average.
When power is delivered to a load is not continuous, generally the common average is used to describe the power delivered over time.
So we measure RMS current and RMS voltage, but mean (common average) power. Assuming a resistive load, RMS current * RMS voltage gives average power.
You can't just multiply Vrms and Irms and get power.Going all the way back to post #23 brings in my original questionRMS current * RMS voltage gives average power.? Now youre talking like the text books. If you had said, average current * average voltage gives average power and average power is not a quantity that is of any use, that would end the conversation there. But when you say, RMS current * RMS voltage gives average power, my ears hear, a German woman and a German man were biological parents of a baby but the baby wasn't German.
Now you guys can continue to post formulas back and forth as much as you want but I would place money on the fact that they are sailing over many peoples heads, and I am definitely included in that group.
A German woman and a German man were biological parents of a baby but the baby wasn't German
Can this be explained without resorting to formulas or engineer talk.?
"The RMS average compensates for the square law scaling of output power with voltage"Now consider a simple 'changing DC' situation, say a system that alternates 1V for 1 second and 10V for 1 second, a 'square wave' going 1V...10V...1V...10V....
What is the average voltage over 60 seconds? 5.5V ( (30 * 1 + 30 * 10) / 60 )
What is the _average_ power delivered to a 1W resistor over 60 seconds? 50.5W ( (30 * 1 + 30 * 100) / 60 )
Notice that in figuring out the average power you have a the voltage _squared_ as one of the terms. Power is simply volts * amps, and in a resistor amps are proportional to volts, so power is proportional to volts^2.
In our example above, the RMS voltage? 7.106V ( sqrt( (30 * 1 + 30 * 100)/60) )
Notice the same average of the sum of squares ( (30 * 1 + 30 * 100)/60) in both the power and the RMS calculation. This is where RMS has use. The RMS average compensates for the square law scaling of output power with voltage. For a resistive load, the average power dissipated when a given RMS voltage is applied is the same as when the same DC voltage is applied.
I will have to "sit" on this phase for a few days and contemplate. At some point life will calm and I will really be able to think this thru. I believe that the key to unlocking this concept is in that phase you posted (and I quoted) above. Unlike the math oriented brain types (that get something out of staring at formulas), I need to ponder specific concepts to get to my "light bulb" moment.
A 1W resistor can dissipate that amount of power for a minute...???...
Perhaps you can fit I²R in there somewhere... :happyyes:As long as you consider only the case of a resistive load, I think you will do just fine with your pondering.
Instantaneous Power=V2/R is a good start.
And since you get the time average of the instantaneous power by averaging V2/R, that is the same as dividing the average value of V2 by R.
And the average value of V2 is by definition VRMS2.
>Ω<.... And unfortunately, the Omega symbol for Ohms, is the letter W in the Greek alphabet font. So when that font doesn't come through, the letter that is supposed to be Omega, shows up as W.
test
capital: Ω, lowercase: ω.
There are several ways to represent non-Latin characters in a web page.
One is to change fonts to a font in which the character desired is a standard character (single byte representation.)
That runs into problems with some web servers and some browsers. It was once the only way to do it in Windows.
Another is to make use of so-called Upper ASCII byte values in a font which contains such extended characters. That does not always work either.
The most compatible is to represent that character using Unicode, in a variable width character representation such as UTF-8. Essentially all modern browsers will accept this and display it correctly, but not all web servers will allow you to enter characters in that format in the first place.
And finally, there is the "character entity" representation, which uses an escape sequence of many bytes to tell what the character is and leave it up to the browser to figure out how to display it. Again, not all web servers let you enter these, though they may use them to render a page.
Its a crap shoot.
Or you can copy and paste like I did.![]()
Works for me. As long as you have someplace to copy from.![]()
