One megawatt at a power factor of 1.jreed said:Mike's First DVD in Basic Electrical Theory uses a term: MVA. I believe this means Mega Volt Ampere. Mega = million. Volt is simple and amp. But how does the term MVA apply exactly? A million volts AND amps combined?
First you must understand that volts and amps "combined" to make volt-amps means they are multiplied together. For example, your typical 200a home service is capable of (240v x 200a) 48Kva, or 48Kw if the power factor is 1, as S$ points out.jreed said:Mike's First DVD in Basic Electrical Theory uses a term: MVA. I believe this means Mega Volt Ampere. Mega = million. Volt is simple and amp. But how does the term MVA apply exactly? A million volts AND amps combined?
After reading your profile I see you are an apprentice inside wireman. You are more likely to run into the term KVA much more often in this field.jreed said:But how does the term MVA apply exactly? A million volts AND amps combined?
On the other hand, if this is confusing enough for you, and you're wondering how it applies to you, think about the instantaneous value of power consumption in kilowatts, and the rate of such consumption, in kilowatt-hours; the latter of which you pay for.charlie b said:Just in case this isn?t confusing enough, let me pile on (no I mean let me add) one more level of complexity.
Actually, it is fairly easy to use the various terms related to power in imprecise ways that may or may not confuse the listener. I would try to avoid the use of the word ?rate,? in the context of ?kilowatt-hours.? Nothing is a ?rate,? unless it has the sense of something happening during a period of time. It is not obvious from the name, but the term ?watts? (or kilowatts or megawatts) does have the sense of ?during a period of time.? It is the amount of energy that is consumed (or generated by the utility) over a period of time. A ?watt? is defined as ?one joule of energy in one second of time.? We just see the word ?watt,? and we don?t see the ?in one second of time,? but it is certainly there.LarryFine said:. . . think about the instantaneous value of power consumption in kilowatts, and the rate of such consumption, in kilowatt-hours. . . .
Actually, when filling up, and adding the miles traveled into the mix, I end up with miles per gallon.charlie b said:At the end of the trip, you refill the tank, and you are measuring that task in terms of gallons alone. In this instance, we do not have a single word that carries the meaning of ?gallons per hour,? so the nature of that phrase (i.e., being a ?rate of consumption?) is fairly obvious.
