Hello Everyone,
I was wondering if someone may have experience dealing with 3 phase 240 volt systems
We are currently wiring a printing press. My client got this press out of a different plant in another state. The electrical contractor at the plant where it came from gave me the power requirements for the printing line. I was told that the press required 240 volt , 3 phase , center grounded. There are a few other parts of the press that require power but the loads are mainly 240 volt , 20 amp and 30 amp , 3 phase , center grounded. The plant where the press came from had 480 volt power.
The plant that I work in has only 3 phase, 208/120 volt Y. My local supplier of transformers supplied us with an isolation type dry transformer, 75 KVA. The transformer goes delta 208 to delta 240. The main 100 amp feed to the press goes to a disconnect then to 3 dry type transformers that step the voltage from 240 to 380. On the line side of the disconnect the wires are red, black white, red and green. On the load side the wires are brown orange yellow , white and green.
I am trying to figure out how to achieve center grounded 240 Volt? Or do I just feed it 240 Delta?
