mslowley
- Marion, NY
I'm looking for clarification on the following.
Our facilty checked GFCI's this past month and discovered several circuits failed the test. All of them originate in the same 208Y/120 VAC panel supplied by a 480 Delta - 208Y/120 transformer nearby. Upon inspection I see no bond between the neutral and ground bars. This concerns me because the test was conducted using a handheld device (Greenlee) for the purpose, those same circuits are GFCI breakers in that panel and the test button on each of them trips the circuit 100% of the time. If GFCI's work by comparing current out vs. in, why does the breaker test button trip and not when there is a load test conducted? Once we bonded the X0 to Ground, no more problems.
