wwhitney
- Berkeley, CA
- Retired
Your derivation shows that absent outside forces, the work done on an object starting at rest will equal the resulting kinetic energy of the object. Which agrees with conservation of energy.work (or energy depending on context) = F d = m a d
d = v t and 1/2 v = a t or a = 1/2 v/t
substituting
work = m 1/2 v/t v t = 1/2 m v^2
2 work / m = v^2, not work/d, that equals Force
Air resistance is a dissipative force like friction, energy conservation arguments aren't going to work. The energy lost to drag F over a distance d is just F * d. And your initial observation that F varies as v2 means that the energy you need to overcome drag for a given distance also varies as v2. In other words, at speeds where the energy required to keep the car moving is dominated by air resistance, the range you'll have for a fixed size energy source varies as v2.
Cheers, Wayne
