jimwalker
- TAMPA FLORIDA
How would you handle fuse selection to a suction pump that only says 16 amps at 230 volts ? The book that comes with it is missing.I have a fuseable disc fed with #12.Second promplem is this thing says 115/230 but only staes the 1 amperage.The factory whip has 1 white wire ,1 black wire,1 green wire.The installer says it 230 volts.Would you hook this up on only his word as 230 ?
