howardrichman
I'm wiring two a/c condensors separately. 17.5 amps each(max brkr 25A). do I calculate the conductors rating at 120% of the load (21 amps), install #10 gu. copper on a 20 amp breaker? Could I use 12 gu. copp; or Does art. 240-4(d) referenced by art. 310-16 prohibit me from doing so. Also; would I need to use a 25 A breaker if i use 10 gu conductors even if a 20A will hold?
Thank you. HR...
Thank you. HR...
