brother
Ive been on many jobs and i have seen some guys who never derate, they just cram as many wires as they can in some pipe and call it a day. I try to follow as much code as possible and i even do the derating of wires even though i have to admit i have NEVER seen a fire or melt down cause people over stuffed conduits and did not derate.
But just to get your opinion, do you think there should be some leeway in the different sizes of conduit when it comes to derating?? for example if you have 12 wires of size #12 thhn in 1 inch pipe should you get a break from having to do the 50% derating as to if they were 12 wires in 3/4 inch pipe?
Seems like even though it may be a small difference in the heat its still a little different in the in heat in my opinion. what do you think? Reason i asked is because im doing a job that it would be lot easier than having to derate those wires cause the conduit runs to my area i need to go, but cant do it without upsizing everything to #10. Even though the most amps ive seen on any of them is only 6 amps. and this is at full load.
