Howard Burger
- N of Anchrage, AK
T310.13 tells me XHHW is rated at 75 degrees in wet locations. We are planning on pulling 10 ccc underground for a bull rail, which would require 50% derating. Since XHHW is 75 degree wire in wet locations, can I still use th 90 degree column of T301.16 to derate the #10 from 40 to 20 amps, or do I need to use the 75 degree value? I see XHHW is shown under 'types' at the top of both the 75 and 90 degree columns.
