I really intended to state the following conditions they (the event) are distributing 240V power comprised of 2 - 120V legs "A" and "B" from the service which has a neutral "C" , so it's probably a 120/240V 4 wire delta single phase. At the distribution junction #5 pull box that they have connected in the vendor service distribution box,, there's only 2 - 120V legs and a ground that run back to the main. It is strictly intended to operate 240V load only no neutral is present or required for that purpose. However they went in my opinion a little " Old school" by being able to derive 120V branch circuits for the vendor connection by using the Ground , thereby energizing the ground back to the neutral / ground bond at the main panel. There's no seperate ground in the distribution, no ground rod, no transformer in the distribution box creating it's own neutral. I had to change my 4 wire L14-30P plug (30Amp 125/250V rated 3P 4 wire) out to a three wire L6-30P (30Amp 250V 3P 3 wire)
eliminating the ground and connecting the neutral wire to the ground screw on the plug, essentially cheating my panel inside the trailer to think that it's getting 2 120V branch feeds, which it is but my contention and question is "IS THIS SAFE"? and if not how many specific NEC violations have just been committed? Please site specific code article to win the booby prize.
Thanks ,
sorry for the confusion on the first pass and for potentially the second
