I am trying to add an on/off switch to a piece of equipment. I am using Eaton's M22 series of switches. The contacts are rated at 10A resistive and have not inductive ratings. I have heaters, compressors, fan motors, and solenoids in my equipment.
I know I have to keep the on/off switch away from my compressors and motors since they are not rated for inductive loads. The same would have to hold true for the Solenoids right?
I also have the heaters. I can remove power from the HMI and control boards, therefore removing power from the heater SSR. Or, I can place the on/off switch so that it removes power directly from the heaters as well as the HMI.
This could be seen as extra protection, by ensuring that the on/off switch directly breaks the heater load, or it could be seen as an operator hazard since the on off switches contacts will now have an extra 5A going through them.
I am leaning towards only removing power from the HMI and Control boards and avoiding the refrigeration solenoids and heaters all together. Does this seem like the more sound approach?
