Now if that means you need to come to look during a scheduled shutdown so be it, if it is going to cost you more to do so then you need to charge more to do so.
I would gladly come back during a scheduled shutdown if there was one :rant:
If the customer will not let you poke your head in at all - they need explanation that doing so may result in errors in your finished product and you will not take responsibility for such errors if they will not work with you.
Oh yeah you have no idea the notes that go into proposals and emails about that commonplace situation.
I don't especially care for boilerplate specifications that include things that don't even apply to the current project - that fact alone means the designer may have missed something IMO. Designer could still use a boiler plate, but one that gets information adjusted to fit the project, at least he has to go through the specs and may see something that needs attention instead of just handing us a one specification fits all listing.
I use my tailored "boilerplate" specifications for sections that never change project to project (are changed when standards update, new products that I prefer to use, etc.). Such sections are things like conductors and raceways and boxes. While I do have "boilerplate" specification sections for specific systems such as fire alarm or access control, all of those specs are looked through each project.
While you as a contractor may not like information that isn't "project specific", as a designer I am trying to not only clearly and concisely produce a product that is construct-able and code-compliant, I am also trying to make a reproducible product. I also work to an amount that was bid on the project. My budget is limited, unlike how some contractors think. So I will not scrub every piece of non project specific information from my specs, unless paid the additional amount by the client to do so.
Leaving in extra information also saves me time as quite often I may disbar a certain installation style on the drawings due to the type of facility or because we are going for a certain finished look. But quite often in the name of "cheaper and faster" (and uglier but that is never mentioned) have the owner answer an RFI allowing it without consulting me. Well my specs still cover that type of installation so I don't have to come back and either a) answer endless RFIs because it's not mentioned, b) Have to issue an addendum (usually without additional fees no matter how justified) to update all applicable spec sections to accommodate the previously disbarred installation method, or c) Have the contractor go cowboy because it wasn't covered knowing I don't have a leg to stand on to fix code-compliant but shoddy work due to no specs.
We designers don't do what we do to screw the contractors or make their day suck. We are in it with you, working on limited information, time, and budget. No matter how delayed the answer or how complicated the problem, my deliverable date is usually etched in stone as well.
I did not share enough info- No one is expecting you to walk about with tools in your pocket. But if you spec equipment, contractor reports it doesnt fit or work do you tell them to 'make it work' ? Or maybe get photos or go and see it. This post wasnt to attack all designers. It was an exasperation due to some of your fellow PE's. Its not all designers, but a enough of the work I interact with, review or just look at are sloppy with life safety systems and its becoming a trend. This is not just one or two firms.
If the contractor reports that it doesn't fit, my first request is for pictures and suggested course of action, as the contractor is in the field and usually has an idea of what they want to do before they call me.
As for life safety systems, my plans will indicate that the fire alarm (only one I'm usually directly responsible for) is a suggested layout but is design build by the contractor. Yes I know you don't like that, but I am very up front about it and it's due to my firm not having a fire protection engineer who can officially sanction said fire alarm layout. But we do our best to make our plans as accurate to the code requirements on it as we can.
Apologies for the rant, I just get frustrated when contractors think every designer knows every specific detail about every job they ever did. Especially when I usually have 2-3 jobs in various stages of construction and 2-4 in various stages of design at any given time. We do the best that we can with the time and material we are given.
